Old 01-27-2006, 10:51 PM   #1
rnoswal
rnoswal's Avatar
Will it go into any other gears? When you push the clutch in and try to put it in gear does it make a grinding sound? If it won't go into any gear when you push the clutch in, it might be a bad master or slave cylinder or both. It just might not activate the clutch far enough to put it into gear. This is not an uncommon problem. Check the clutch fluid level, then if all else fails it might be a completely worn out clutch disc/pressure plate.
Let us know.
Russ
