Old 01-26-2006, 05:18 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 94T88Widebody
Its a GT47-88.... I never said it was a Greddy
Actually you did, when you said this (qft):
Dual Fuel lines, T88 turbo, Virtual Works intake, 1600cc injectors, AEM, custom 5 inch exhaust, Block is unmodified at this time...
Fact: The only company that makes a turbo generally referred to as a "T88" is GReddy. Although Turbonetics also makes a turbo called a Y2K T-88, that particular turbo isn't generally referred to without including the prefix/acronym "Y2K".
As I said earlier (and no matter who manufactured your turbo), your engine bay is sweet! This was the point of my post, not to start an argument about turbo nomenclature. In addition, there's a very significant horsepower difference in a GReddy T88 and (what we now know is) your GT47-88 ... my comment about your turbo not looking like a GReddy was trying to clarify the exact specs of your setup, for future troubleshooting purposes.
Also note that (from the pictures you posted) I don't see either an HKS DLI or an AEM CDI mounted in the engine bay. If you're not running an ignition amplifier with your AEM, you will experience ignition misfiring under high boost. Although this might partially explain the misfire you talked about, the 18+psi you were running on 91 octane pump gas was likely a primary contributor to both your melted sparkplug and your "100 - 120 psi" compression.
Again, to best recommend next steps to help you avoid melted sparkplugs, low compression (engine damage), etc. in the future, please shed some light on your horsepower goals, identify the exact type of fuel you plan to run (c16 full-time?), and detail your application (eg. drag racing?). ...and do you plan to spool up that big GT47-88 with any NO2?
P.S. Did you buy your Supra from Chris Msungi? I showed your engine bay pictures to a friend of mine, and he says he recognizes your widebody Supra (less the HKS Twins) from when Chris brought it to Tx2K3...
Life begins at 30psi.
