Thread: Car Choice...
Old 01-26-2006, 03:24 AM   #10
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by NvrFstEnuff
Cool man your really helping me out. Personally I didnt like the idea of the "sequential" anyways. Seems as if there would be a slight or even larger downtime where the boost drops for a bit then spools back up with the second one...
Toyota invested a LOT of resources to make the sequential transition as smooth as possible. There is a separate actuator for the prespool...and the oem fuel & timing curves have been extensively 'tweaked' too. Oh, and it doesn't spool back up with the second one after the transition...it spools back up with both.
...What size are the stock turbo's on them now?...
CT12B's.
...I was thinking of going with a 60-70mm single and just keep the boodt at a low/moderate level for around 400 on the street...But come track time I want to turn it up a bit more to around 500+ if possible.
You don't need a 70mm turbo to make 500rwhp...a 60 would be fine.
Life begins at 30psi.
