Old 01-25-2006, 07:13 AM   #3
mrnickleye
mrnickleye's Avatar
perhaps the mechanic meant the fuel injectors were carboned up. This can be a common problem. Do as mentioned above, and use fuel injection cleaner in the fuel tank to clean out 'varnish' in everything, and carbon on the tips of the injectors.
Dirty injectors can stick open, and/or spray in a crappy pattern, which can cause engine running problems.
