Thread: Heater Problem
Old 01-24-2006, 11:42 PM   #1
mrnickleye
mrnickleye's Avatar
If you remove the cover under the glove box (a few nuts, 10mm socket), you can look under there and see the resistor. 2 phillips screws and the connector. Pull it out and look at it. If its got bad coils, it will be obvious. Take it to auto electric to solder it, then put it back in.
