JDM 7MGTE vs. Amercan cams
Hi. Anyone know if the cams in JDM 7MGTE engines are milder than the ones for American engines? For MkIV engines they are different due to a 280 HP limit in Japan.
The 7M lobe height is in spec according to the American TSRM, but the base circle diameter is not given so lift cannot be figured, let alone duration.
Any info would be of help. Thanks.
BernieK
