Old 01-19-2006, 05:04 AM   #1
mrnickleye
mrnickleye's Avatar
The center gasket is seperate. Its available thru the dealer for about $35. It is for keeping debri out of the spark plug holes. You could save $$ by cleaning the old one up with a wire wheel.
The VC gaskets are rubber that fit into a groove on the VC cover.
Use silicone gasket sealer at the corners, and at the cam caps in the front.
