Old 01-18-2006, 01:04 AM   #34
Littlestan
Littlestan's Avatar
Ok!
Here's some pics of the new version sills. They might not look too different,
but they definitely are. The old versions were exact copies of the stock sills.
The new versions are straight cut on the edges, have a wider base plate, and
I've molded it so the bottom radius is larger enabling you to run wires from the
front or back of the car under the sill if need be.
Shopwise, I estimate only 2 more days of drying out before it's good to go
again. Can't wait to start working again!
Strannik, I probably won't be making CF bonnets if j3pz is correct. I haven't
searched around to see if other comapnies are making them, so if there isn't,
it's definitely a possiblity.
Anyways, enjoy!
-=Littlestan=-
[ST Composites]
ID:	151   Click image for larger version
