Old 01-17-2006, 03:06 PM   #10
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
The list I've made is not necessarily meant to be followed in that specific order.
MSD stands for mulitple spark discharge. There are other companies that make similar products. A high powered coil is controlled by a computer allowing for mulitple sparks for several degrees (angle wise) throughout the duration of the spark cycle of each cylinder insuring complete ignition and combustion. This in turn gives more power, easier starts, and usually also translates to better gas mileage.
Yes, when I meant ignition, I meant the whole package. Wires, plugs, cap and rotor (if applicable), a coil, and a multi-spark box.
Function Over Form - Form Follows Function
88 MkIII Jurbo
Bullz_EyE is offline   Reply With Quote
