Old 01-14-2006, 03:58 AM   #1
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
If you have rod knock, the crank will be scored and need to be cut.
I can't see how the connecting rod would still be reusable.
I dissected an engine that had a spun bearing in the rod, and it was such a mess in there. It needed a new rod and a new crank.
As far as what is best for you. I really can’t tell you!
There are way too many factors: time, money, experience requirements for the build, etcetc.
Rebuilds are great if you can source good parts and go from there.
Buying a JDM motor is a quick way of doing it.
But you would be getting an old motor, but a quicker solution.
Depends on how long you want to keep the car also.
Sometimes putting used parts in a used car is the way to go.
I once sold a used part to a guy and said that the part will probably outlast his car.
Well, different people have different philosophies, but I think I gave some ideas on both.
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
Last edited by TONY!; 01-14-2006 at 09:41 PM. Reason: Removed the "why do you have cap locks?" part out :/
TONY! is offline   Reply With Quote
