Originally Posted by 94T88Widebody
Okay...I thimk we may be getting somewhere..... I hooked into the AEM .......no Engine RPM...
Would this be a good time to assume my CPS system has a problem...?
It's a good guess. It's possible your loose timing belt knocked off the 'toothed' crank position sensor gear (attached to the crankshaft's timing belt gear) when you ran with a broken tensioner bracket...
Can you post pictures of your engine bay?
