Old 01-08-2006, 04:20 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by SKILMATIC
...O and btw, do you know if the is300 and the supra engine craddles are the same? I have always wandered this.
I know the cradles are different, and as a result the oil pans are different. That said, I'm not an IS300 expert...I'd guess the motor mounts are different too - but even if that is the case, the IS300's motor mounts will bolt to the 2jz-gte block just fine.
Life begins at 30psi.
