Old 01-07-2006, 07:14 PM   #2
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
You know for the teeth of the timing belt, I thought there was only one belt for the 7M motor/s...?
On my 7M-GTE motor, I have a 159 tooth timing belt.
If someone can confirm they are the same as the N/A models, then it would be 159.
I would be interested in knowing if N/A's have different belts than Turbos.
Edit: I would be very cautious of a heating problem. Overheating can crack blocks (seen it happen on a 7M) and can warp the head too.
If you are on a road and you have a temp spike, it may be so fast and you may not even notice, while the needle could be beyond where the gauge reads or intended to even measure.
TONY! is offline   Reply With Quote
