Old 01-07-2006, 04:11 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Big Jimbo
...Does NAWZ blow your engine up? No, but you can if you install it wrong or spray too much/long. If you plan to run nitrous all the time, i would look into getting your computer tuned to add more fuel in the mixture because nitrous tends to lean out the air/fuel mixture. If your air/fuel mixture is too lean, you can burn holes in your piston (VERY BAD and will cause you to have to rebuild your motor)...
Agreed. Also for larger shots of nitrous you need to be able to retard your ignition timing...and be prepared to spend lots of time on the dyno TUNING the resulting setup.
Life begins at 30psi.
