Old 01-07-2006, 03:27 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by SKILMATIC
I remember reading in turbo mag this. Here is the article. I hope this helps out.
http://www.turbomagazine.com/features/0312tur_is300/
Hope the link works
Skil, thanks for posting this link.
I agree that a 2jz-gte typically isn't a drop-in solution for a 2jzge-equipped Lexus...for example, there's no reason why an engine bay designed for a 2jz-ge should already have room for 2jz-gte's turbos.
...BUT (again, for example) the oil pans in that article didn't need to be "custom" for the sake of the 2jz-gte shortblock ... to make a complete 2jz-gte fit in the IS300 engine bay (again other than the turbo(s)) they only needed to use IS300 oil pans bolted to the 2jz-gte...and they do bolt directly on.
Also, I'd be willing to bet that they could have used the oem motor mounts IF they didn't have to worry about turbo and/or transmission clearances. In other words, it wasn't any 2jz-ge<->2jz-gte shortblock differences that necessitated the modified engine mounts. These custom motor mounts they chose to use (for other reasons) are what necessitated the custom oil pan.
Life begins at 30psi.
