Old 01-07-2006, 03:56 AM   #1
Big Jimbo
Big Jimbo is on a distinguished road
I would look into different cams, exhuast/headers, different aircleaner, if your an auto. i'd go with a stall converter.
Does NAWZ blow your engine up? No, but you can if you install it wrong or spray too much/long. If you plan to run nitrous all the time, i would look into getting your computer tuned to add more fuel in the mixture because nitrous tends to lean out the air/fuel mixture. If your air/fuel mixture is too lean, you can burn holes in your piston (VERY BAD and will cause you to have to rebuild your motor)
I would go with a small turbo of some sort. Maybe a turbo off of another car/supra
Big Jimbo is offline   Reply With Quote
