Old 01-04-2006, 10:35 AM   #1
mrnickleye
mrnickleye's Avatar
Thumbs up You Can Do It !!!!!!!!
Bring on over to my shop. I know supras well, and I've never ripped anyone off. There is enough work to make a good living, AND be honest.
The ripoffs are just lazy bastards that actually enjoy stealing from you !!
I've fired some when I was foreman at the Toyota dealer.
You don't EVEN wanna know some of the crap those kind do to your car, or don't do, but charge you anyways.
It sounds like you have some mechanical abilities. Get a Chilton manual so you have a reference book to get greasy while you fix things yourself. Use the TSRM, and print out the pages you need to do a particular job.
Ask all the questions here before tackling a job that may lay up your car for a day or 2.
That throttle body will come right off with a 3/8" 12" extension and socket. Those valve covers are easy to get off with a BIG tipped phillips screwdriver.
Make sure you use a fender cover, even a towel.
Take some photos before you start if you need, so you can see where it all goes back.
Get a muffin pan to keep the nuts and bolts seperated as you remove them. This will make re-assembly much quicker, and less headache.
Get all the parts and gaskets ahead of time. Keep 2 cans of 'brake cleaner spray' on hand. A magnetic tray is handy, or an old speaker magnet.
VC gasket job won't take you more than 2 hrs. max.
