Old 12-28-2005, 12:30 AM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Removing the light bulbs is very easy. But after removing the plastic panel that holds the bulbs and little reflectors, how do I remove the big red lens itself? I found 3 small screws and removed them, but couldn't move the lens at all. Guess I'll use a mirror to see if there are any more screws in there. Sure wish Toyota had simply used a few screws from the OUTSIDE to hold the lens on.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
