Thread: timing help
Old 12-23-2005, 12:43 AM   #1
Bullz_EyE
Bullz_EyE's Avatar
Bullz_EyE is on a distinguished road
I'm in the same boat. You need to make sure the engine is at TDC 0 degrees. You do this by rotating the crank so that the timing marks on the cam gears line up with their perspective marks, as well as zeroing the crank pulley on its mark. You then need to open the cover on the CPS and align the trigger so that it's slightly before where it lines up on the trigger because when you put the CPS in, it will rotate clockwise as the gears mesh. Keep trying so that when you put the CPS in, the trigger is aligned. Make sure you do this with plenty of play to adjust the CPS like a distributor.
Then refer to this page to set it:
http://www.cygnusx1.net/supra/techti...ng_timing.html
Bullz_EyE is offline   Reply With Quote
