Old 12-16-2005, 07:30 PM   #1
rnoswal
rnoswal's Avatar
Just remember, it won't get better. Start looking for a replacement soon so you can use all the gears again. You can check the trans fluid and if it is low then top it off and maybe the noise will abate some and make it last a little bit longer. All these old cars start to get the hardening of the seals, they start leaking and then it is too late. If you do replace the tranny, make sure you replace the rear main engine seal and pilot shaft bearing along with the front and rear seals on the tranny.Let us know
Russ
