Old 12-14-2005, 11:22 PM   #34
snowball
snowball is on a distinguished road
BFR1992T vbmenu_register("postmenu_3741248", true);
Moo
http://supraforums.com/forum/image.p...ine=1117678453
Trader Rating: (0)
check the fuel pump first. put a paper clip between FP and +B in the check connector. Turn key to ON but do not start the car. You should hear the pump running and fluid flowing in the engine bay as fuel recirculates back to the tank.
You can check the fuel injectors by putting in dry plugs and cranking it over a few times - some of the plugs should become wet with fuel.
snowball is offline   Reply With Quote
