Old 12-11-2005, 11:23 PM   #1
kwnate
SP58GT
Yes undo those bolts. Loosen a little at a time and turn the engine over (by turning the crankshaft bolt) to the next. It helps having a helper to turn til you see the next bolt, you want to go evenly to releive the pressure. there are 6 or so. then it will slide right off. Access them through the inspection covers on the tranny. Good luck.
Nate
