Thread: hatch
Old 12-07-2005, 06:31 AM   #1
mrnickleye
mrnickleye's Avatar
Thumbs up
And the 1/2" round ones along the back, on each side of the latch, out towards the ends. I used to spray silicone, but now I dab a tiny smear of clear silicone grease. Its like vaseline, but not as 'wet'.
Also if you look closely, you'll see some 'rub' spots up along the top, where the wiring harness and washer hose rub the channel in the body. Put some there too.
Make sure your latch is adjusted so the hatch is tight when closed.
