Old 12-02-2005, 07:04 PM   #1
SupraMan1784
SP58GT
i will have to agree with RS87 at the moment, a turbo gets you power, yes, but there are other issues that you must attend to ...assuming you havent upgraded them yet, bigger turbo means ull need a better cooling system otherwise the engine will run too hot, then are other components taht also must be addressed, teh big one being the headgasket, but 14lbs on stock 7m is possible, if the right components are put into it, the block can handle the power, it just depends on how well you take care of the motor and the number of preventative measures u take to allow it to handle that amount of boost
Now: Saving for an MKIV
Broken Rides:
