7mgte is no less reliable than 7mge. It was truly designed as a turbo from the start with oil squirters under cylinders, additional cooling, etc
Head gasket failures affect all MK3 Supras...eventually.
If you want to bring out the true character of this car, do a manual transmission swap before anything else. Make sure it's R154 with beefier gears to handle extra torque.
