Old 11-29-2005, 08:20 PM   #1
skunk
skunk's Avatar
skunk is on a distinguished road
Default 14 psi
I shimed my waste gate and run a straight through exaust I think you will be fine you will only hit max boost running at high speeds, 12 psi is fuel cut, so i would just work of that, play with it if you hit fuel cut, back off a little, and you really cant break the turbo doing what your talking about, the ct26 is more than capable of pushing 14 to 15 psi stock
skunk is offline   Reply With Quote
