Old 11-23-2005, 04:42 AM   #1
rays87turbo
rays87turbo is on a distinguished road
You could use the harness and injectors from the 87. You could rewire the 87 harness with the 89 connectors and use the 89 injectors. Swapping the injectors would be the easiest way. 87 or 89 they're both 440cc injectors, as long as they work it doesn't matter which ones you use.
rays87turbo is offline   Reply With Quote
