Old 11-22-2005, 04:30 AM   #1
rays87turbo
rays87turbo is on a distinguished road
Junkyards or ebay are good bets. You should be able to get one easily at supraforums.com or supramania.com....lots of guys will be willing to get rid of it for ~$65 or so. Also, have you tried just disconnecting it and trying to start it? The car should run w/o the signal....not very well....but the ECU should just "assume" base temp and flow settings if theres no AFM signal. The only time this might not work would be in extreme cold. I believe the default settings are somewhere aroung 70*. I've mkiiis run w/o the signal up to about 100*, so I think cold would be the big problem.
rays87turbo is offline   Reply With Quote
