Old 11-21-2005, 03:36 PM   #2
Burn N' Up
Burn N' Up's Avatar
I need the deal to pop the steering pit man arms, its a low profile tight space things. Also going to need the two SSTs to remove the rear wheel bearing, apparently its an SOB to get out of there without a bearing remover, kinda looks like two letter Cs with bolts connecting the top and bottoms so they are set like this <> and another removal device to push the bearing out through the hole in the center. Not sure what its caller, but its for the rear bearing removal.
