Thread: Supra Trouble
Old 11-19-2005, 12:47 PM   #1
rnoswal
rnoswal's Avatar
Just remember that each time you try starting the car, the cold start injector starts spraying. After a couple of times it will almost flood the engine. It will probably start but shake and stutter until it clears out the extra fuel. Make sure there are no vacuum leaks. Hoses get brittle along with gaskets. Spray some WD40 around those things when it is running to see if it changes the running. Most of the time it will rev up slightly and run a little better when you spray a leak.
Let us know
Russ
