Thread: 7m vs 1jz
Old 11-13-2005, 11:05 PM   #1
the_fallen
the_fallen is on a distinguished road
similar power can be pulled from both engines, but the jz will take it for longer. the m series block has been around for 30? years now, so is getting a bit long in the tooth and should really be put out to pasture in my opinion. however toyota_guru is right in that the 7m's are cheaper and more readily available, so when you blow something, it would be easier to find a replacement.
the_fallen is offline   Reply With Quote
