Old 11-10-2005, 05:56 PM   #1
SupraMan1784
SP58GT
both paths will get u a significant amount of power, the price will almost end up the same since...if making big power you must beef up the internals with some low comp pistons and internals, the turbo motor is alrdy prepped to handle large amounts of boost, and the na has a higher compression, i would personally go with teh 6spd tt swap...but then again if you are on a tight budget i would stick with what you have and get a single turbo kit, but at the moment run low boost...probably around 8-9psi until u can upgrade the internals and then in that case you can go crazy and up the boost
Now: Saving for an MKIV
Broken Rides:
