Thread: 1989 MkIII
Old 11-08-2005, 09:47 PM   #1
Levi1717
Levi1717's Avatar
Levi1717 is on a distinguished road
when u go to look at it have the seller start it up and let it run......after it runs for awhile check to see if any fluids are leaking out under the car. also watch the tempurature gauge. also ask him if the a/c heat and lights all work (i bought mine and none of that stuff worked and now its a hassle to fix) also to see if the engine is in good mechanical condition listen for any weird noises and i check the oil if the oil is really black and thick then it prolly hasn't been checked regualarly.
oh and if u buy it make sure its got enough gas to get u back home........i found that out the hard way.
Levi1717 is offline   Reply With Quote
