Old 11-03-2005, 06:03 PM   #1
Burn N' Up
Burn N' Up's Avatar
First, before you spend an ass load of money on souping, make sure your are is mint stock. Fix any clicks, clunks, shimmys, shutters, etc. Things like a new fuel and oil filter will help you out. And of course any other maintenance issues should be addressed. Then....
Cheap and easy, K&N FIPK 8.9 horses at 5300rs, 3" turbo elbow available from Suprra_girl, 3" Down Pipe from Suprasport.com either the RT or Cooleeze i'd recommend. And then of course either no cat or a 3" high flow cat (if you plan to make it a street driver to stay in smog rules) and then finally 3" exhaust pipe and muffler out the back. That should net you quite a few horses quite simply and welllllllll under your 1200. You should have plenty left over for something more drastic when your ready like a full intercooler/hardpiping rebuild or uping the boost. And an AFR gauge...
