Old 11-02-2005, 04:03 AM   #2
1988gte
1988gte is on a distinguished road
Heater...while engine is running, just unplug the vacuum line from the engine, going to the VSV (wires to it) by the heater water valve, then plug it into the heater valve. Valve should work, you'll see it move. Normal operation is that water always flows thru the heater core, except when the temp controls are set to 65*.
Any pictures on this process?
1988gte is offline   Reply With Quote
