Old 11-01-2005, 05:14 AM   #2
joel w
joel w's Avatar
first the lock, pull your door panel apart and lube and manually work the lock mechanism inside the door, it will probably loosen up just fine,
second the screetch.. check your belts, alt, water pump, power steering, if there loose, tighten them up and try it?
