Old 06-30-2022, 06:09 PM   #1
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Here is a link to the online manual. You say you have a GE so it starts there.
Ignition timing:
http://cygnusx1.net/Supra/Library/TS...aspx?S=IG&P=17
Camshaft timing:
http://cygnusx1.net/Supra/Library/TS...aspx?S=EM&P=29
Make sure the airflow meter is plugged in and that the bundle of ground wires on the intake side under the intake manifold is tightened down.
I'm assuming you checked the valve clearance of each valve to be within specification.
Valve clearance:
http://cygnusx1.net/Supra/Library/TS....aspx?S=EM&P=8
Here's a link to another Supra website that may be of help to you.
https://www.supraforums.com/forums/m...986-5-1992.13/
