Old 08-16-2021, 01:25 AM   #1
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
When the AC is engaged the computer bumps up the rpm's and when it shuts off it returns it back to idle. Try cleaning the idle speed control valve and be sure that the rubber check valve inside is pointing in the right direction on a GTE and not damaged. The motor is a stepper type which means it only moves slightly when each coil section is energized manually. There are 6 contacts. The order that they are energized determines the direction that the cone end moves to control the flow of air. Here is a link to the online supra manual for that testing.
http://cygnusx1.net/Supra/Library/TS...spx?S=FI&P=106
