Old 10-05-2019, 09:41 PM   #1
MK3MKB
MK3MKB is on a distinguished road
still working with this, I've checked the grounds on the intake. I've checked the EFI fuse. checked continuity across CPS. I doubt the alarm is the cause, I bought the car without a battery. Both sides of the injector plugs are hot at all times. I used a my test light while cranking to see if the light goes out on either side, it does not. I checked for any fluctuating using a multimeter, reads 0 volts while cranking with the probes on either side of the injector connector. One interesting note is the previous owner grounded the knock sensor wire.
MK3MKB is offline   Reply With Quote
