Old 09-20-2018, 01:04 AM   #2
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Did you check the fuel pump relay? Other than that you can run a direct connection to the starter solenoid terminal or use one of those push button remote starters for testing purposes to see if it cranks. Try cranking with the key in the ON position. Just be careful down there. I would disconnect the battery while you are wiring up your remote switch. I don't know if the security system locks out the starter but when I had problems with mine the alarm would sound when I put the key in the door switch and turned it. The switch inside the key lock needed fixing and I repaired it. There is a crescent moon shaped copper contact inside the switch that rides on top of the key lock and had come disconnected from the plastic post that held it in place. I put the clip on the post and Re-melted a mushroom on top of the clip carefully. There's not much to work with.
