Thread: Clutch problems
Old 09-08-2018, 06:28 PM   #1
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Make sure that the clutch pedal free play is not over adjusted. That pin that fits in the back of master cylinder should wiggle just a little and not be tight up against it. There's a lock nut and you also need to hold the other slot With the 2nd wrench to Loosen and tighten it. The procedure is detailed in a good repair manual either Toyota or Haynes. If there any air in the system it will expand with heat and cause the clutch to act automatically and make it slip.
