Old 11-21-2016, 01:38 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Constant flashing CEL while in diagnostic mode indicates that there are no codes stored.
I'm not positive on the best way to check the fuel system operation on a 1JZ, but if it's anything like the 7M and it has a similar diagnostic port, you should be able to jump a wire from FP to B+; with the ignition key set to "Run", this provides the 12V positive power through the fuel pump circuit and you should have a constant running fuel pump until you turn the key off or remove the jumper wire.
