Old 09-27-2015, 10:49 AM   #1
Busted Knuckles
Busted Knuckles's Avatar
My 'play around', do you mean shaking the window in the frame, or just using the switch to keep lowering and raising it until it goes up? I ask because my driver's side window will, on occasion, jam as I try to raise it. If I can grab the upper edge and shift it towards the rear of the car, It will un-jam and go up as usual. I suspect a worn bushing, but I haven't removed the door panel to check yet. It also tends to rattle a little bit as I drive, and I can make it stop by cracking the window and rolling it back up. Does anyone know of a source for replacement window lift track bushings?
