Old 07-14-2015, 12:35 AM   #1
Remi93supraTT
Remi93supraTT is on a distinguished road
Carefully inspect the pins in the ecu harness. A friend's Supra had a pin that had come loose, and had partially slipped back into the connector.
You should be able to use a multimeter to diagnose any other issues with the harness/wiring.
Ok thanks a lot will do and ill post back when I find what it was. Thank u for the help
Remi93supraTT is offline   Reply With Quote
