Old 02-26-2015, 06:46 AM   #1
S-mk3-B
S-mk3-B's Avatar
S-mk3-B is on a distinguished road
You can use a JDM engine, you just have to transfer over the EGR components from the USDM engine to the JDM and whatever else (pretty much put them next to each other and whatever the other one doesn't have just simply swap over), hence using the same ECU will be fine. While it's out you should do as much as you can cause even if you get a "low mileage" JDM engine, they could of been sitting out anywhere and who knows what the internal condition may be. Anyways at least change all the seals like front and rear seals, valve gasket, water pump, etc.. And if you want to go the extra mile you could do a head gasket job w/ ARP head studs (cause the 7mge/gte engines are prone to BHGs). Other than that have fun and welcome to the Supra life!
1989 Toyota Supra Turbo w/ Targa Top
White Exterior-Blue Interior
3" Blitz Catback Exhaust System
BIC Divorced Downpipe, Straight Pipe
Megan Track Coilovers
Apexi BOV, Turbo Timer, and Intake
Lexus Projector Fogs
Bride Low Max Replica
S-mk3-B is offline   Reply With Quote
