Old 12-10-2014, 01:27 AM   #1
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
Also, if you plan on going all out a stand alone ECU is the best and only way to go. That being said, a piggy back that lets you tune fuel, and other stuff could go a long way depending on your final HP goals. I don't think the o2 sensor is a factor, but if I'm wrong somebody else can chime in with their 2 cents anytime. If you plan on big HP #'s more bigger injectors is a must and if the 250 lph fuel pump can't handle the power just put two pumps in there and problem solved.
Anyone who has never made a mistake has never tried anything new.
supraheelfan is offline   Reply With Quote
