Thread: Code 12
Old 10-10-2014, 06:25 AM   #1
Busted Knuckles
Busted Knuckles's Avatar
Code 12 - No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked. - Trouble Area: Distributor circuit, Distributor, Stater Signal circuit, ECU.
Sounds like the cam sensor is busted or the circuit is cut. It is in the distributor. The only cam/crank sensor is in the distributor, so a busted sensor means not start.
