Old 06-28-2014, 01:45 AM   #2
The stock fuel system and ECU will handle the 57 trim in MOST cases without issue. You may run into fuel cut at higher RPM but I don't think you should see much of that as long as you're not increasing the boost pressure beyond the stock level.
