Old 05-31-2014, 04:41 AM   #1
supraheelfan
supraheelfan's Avatar
supraheelfan is on a distinguished road
If I get the Lexus AFM do I need to upgrade xthe injectors to 550cc also? N/M i guess only need the 550cc injectors if you install the entire afm housing and not just replace the electronics on it.
Plus I want a more reliable sensor and more than anything else I want something that could help me tune the car eventually.
So to clarify a Lexus v8 AFM/Mass air flow sensor will work with replacement of sensor itself correct? For very helpful info: what other Toyota/Lexsus intake sensors will also work as air flow sensor without having to spend way too much on a used new afm
Plus CRE, the best bet would be to just purchase another 7mgte yellow plug ECU and hope that gets rid of the code 52.
Anyone who has never made a mistake has never tried anything new.
supraheelfan is offline   Reply With Quote
