Thread: Tricky Ignition
Old 03-07-2014, 02:17 PM   #1
ccorbin81
ccorbin81 is on a distinguished road
Good morning,
I pulled out the relay this morning located in the driver kick. Here are the specs I found for testing it.
  • STA - E1 = 17 - 25 ohms
  • +B - Fc = 88 - 132 ohms
  • +B - Fp = Infinite ohms (i.e. open circuit) w/ relay off
  • +B - Fp = 0 ohms w/ relay on
I tested it with my meter and here are the results.
  • STA - E1 = 21ohms
  • +B - Fc = 121ohms
  • +B - Fp = OL
How can I safely energize the relay to test (+B - Fp = 0 ohms w/ relay on)? Or is this irrelevent? It seems the relay is functioning properly, is there anything between this relay and the diagnostic port B+?
Should the terminal where B+ for this relay connects get 12v with ignition on? I don't get any voltage on any of the pins when I test them with ign on and off.
ccorbin81 is offline   Reply With Quote
